Simply follow these steps:
1. Open the document whose numbering you want to convert. (You may want to open a copy of the document so that you don't mess up the original document.)
2. Press Alt+F11. Word displays the VBA Editor.
3. Press Ctrl+G. This opens the Immediate window. (If you get any other type of dialog box, such as the Find and Replace dialog box, then you aren't working in the VBA Editor; you are still in Word. Close the dialog box, make sure the VBA Editor is active, and then repeat this step.)
4. Type the following in the Immediate window:
ActiveDocument.Range.ListFormat.ConvertNumbersToText
5. Press Enter.
That's it; all the auto-numbered lists in your document are changed to manual numbering. If, instead, you want to affect only a limited portion of the document, make sure that portion is selected before you start the steps and then use this command in step 4:
Selection.Range.ListFormat.ConvertNumbersToText
Подручными средствами:
1. в Word'е выделяешь всё, копируешь
2. в WordPad'е, правка, специальная вставка, файл RTF, выделяешь всё, копируешь
3. в Word'е просто вставляешь
BorisNik писал(а):ActiveDocument.Range.ListFormat.ConvertNumbersToText
LyoSHICK писал(а):BorisNik писал(а):ActiveDocument.Range.ListFormat.ConvertNumbersToText
Ничего себе!..
Неужели без VBA нельзя?
BorisNik писал(а):Дык делов-то. Alt + F11, Ctrl + G, спейстили с блюдечка
