SDL Multiterm 2009. Запускаю - выдает ошибку и закрывается. Пробовала переустанавливать - то же самое. ОС - Windows 7.
Что можно сделать?
Нюшка писал(а):Win7 64-битная
Deleting the Trados.Interop.MTTMO2 assembly out of the Windows registry
Close all SDL Trados applications.
Click on START > Run...
Type regedit into the dialog box and click on OK
Go to the folder HKEY_CLASSES_ROOT\Installer\Assemblies\Global
Search in the list on the right hand side for:
Trados.Interop.MTTMO2,Version=1.0.0.0,Culture=neutral,PublicKeyToken=4316ebe69d6f1d49"
When you found the registry key, highlight it and press delete or right-click on it and choose delete.
After you deleted this key manually close the Windows Registry Editor
Deleting the assembly out of the Global Assembly Cache
Type assembly into the dialog box and click on OK
The C:\Windows\assembly window opens at the place where you need to search in the list for:
Right-click on Trados.Interop.MTTMO2 and choose Uninstall
A message asking if you really want to delete the assembly appears. Confirm the message by clicking OK
Close the C:\Windows\assembly window
