Регрессионная модель Кокса (handle ties in the event times)
Сообщение lampa » Вт май 04, 2021 23:32
Помогите, пожалуйста, перевести предложение "The exact method is used to handle ties in the event times".
Нашла объяснение на англ. "Survival analysis is generally defined as a set of methods for analyzing data where the outcome variable is the time until the occurrence of an event of interest. One of the methods commonly used in the survival analysis is Cox regresion model which is used to determine the factors that impact on survival times. Cox regression model has assumptions. One of them is proportional hazards assumption and the another one is there is no tied data between event times. However, in real applications, tied event times are commonly observed and Cox’s partial likelihood function needs to be modified to handle ties. It is well known methods that the Exact method, Breslow method, Efron method and Discrete method for handling tied event times.
Заранее благодарю!
lampa
Язык(-и): Eng-Rus, Deutsch-Rus
Re: Регрессионная модель Кокса (handle ties in the event tim
Сообщение Andrew » Ср май 05, 2021 10:16
Не спец в статистике, но есть предположение: имели в виду, что в случае связанных временем событий для учета этой связанности применяется метод Exact (один из алгоритмов вычисления в популярной модели).
Сообщение lampa » Ср май 05, 2021 21:57
Andrew, спасибо!
не могу подобрать русский вариант. Или обработка совпадающих по времени событий или обработка совпадений времени наступления событий??
Tied events are simply when two events occur at the exact same recorded time.
For example, if a study measures time until remission in months and subjects 1 and 2 both experienced remission at month 2, then their event times are tied
lampa
